.21BB (barley alive) into an HPI NMT
I need some help fellas. I've thought about putting the wolfpack radicals mount on my .21BB so i could mount it on my wifes NMT. but the cost is a little too much for me. Any one got an old engine mount that will fit a .21. I'm looking for one that I can just bolt on to the current chassis and that doesn't cost $60.00.
IT MUST FIT A 21!!!!!
If you want to do custom work, you could get Ofna engine mounts off ebay and use those, but you would be doing a lot of dremel work!
Ofna engine mounts, huh? I hadn't thought of that. Thanks GTX. Dremel work? I enjoy it most times it the damn bits don't break every thirty seconds.
Yeah, but with this, all you have to do is PLAN it! Just map out and think everything out before hacking away. If you plan everything right, you will not have to do much work...
Well ahead of you on that one. I got a mount coming should have the NMT big block powered by the end of next week. Let you know how it goes. I'll post some pics.
