Savage 25 starting
Savage 25 starting
when i use roto start wand when first starting the wand is spinning but the motor barly is poping like doesnt sound like its igniting takes a lot of covering the muffler to special tp the finally kicks over what do i need to do to fix
My Feedback: (31)
KY
RE: Savage 25 starting
Sounds like the one way bearing in the roto start assembly on the engine is shot. It will cost you about $20 for a new one. Or you can try spraying out your current one with some brake parts cleaner, or carb cleaner to remove the oil from it, and try it again.
Eric
Eric
