t-maxx not shifting
GA
t-maxx not shifting
I have been trying to fix this problem for the past week and have tried everything. I recently changed the pinion on the engine to a lower amount of teeth in my bro's t-maxx (its a .15 HPI SS and yeah he runs it i fix it) i am not sure if it wasn't shifting before but now it just does not want to shift at all. I have tried loosening the set screw and tightening and a couple of places in between each time taking the truck back out warming it up and then going to speed runs at full temp.
His t-maxx has a .15 HPI SS engine, 72tooth RRP metal spur, foward only conversion and a 16tooth pinion
Any suggestions on y it is not shiftin?
GA
t-maxx not shifting
nah i am running it at about 2.5-3 turns on the high speed needle and it hits the top of its rpm's and just sits there and doesnt shift
btw where in central jersey are you?
GA
t-maxx not shifting
yeah your defiantly right about the track...even though i run 1/8th buggy could still use it for outlaw class lol. and i know where bridgewater is i used to go down that area every so often to visit my aunt. i am all the way up in the corner by PA and NY. There are some decent spots up by me for bashing but nothing spectacular
GA
t-maxx not shifting
thanks but i tried i moved the set screw all the way in and it didn't do anything i moved it all the way out and it didn't do anything and then i took it a couple of turns in between in both cases and it would go into second at all unless i tightend the screw all the way down.
Also i know i am turning the correct screw no the one holding the clutch assembly to the shaft
