Tuned-pipe / fuel recommendations for OS .30VG(P)-X?
Hello,
Ijustbought an OS .30VG(P)-X. I will mainly be using it on a test stand in which I'll be dynoing it at different load/speed conditions andmeasuring fuel consumption vs. dyno reading. I would like some help deciding what tuned-pipe touse with the engine,and also, what fuel to use:
1) What would be a good tuned-pipe if I care more about low-rpm torque than high-rpm horsepower? It would be a plus if Icould find a pipe that's also a bit quieter.
2) Since I will be operating the engine a decent amount at lower-speed/high-load, what would bea good fuel for this type of running (brand, % oil, % nitro, etc.)? Would the same fuel be good for when Ioperate athigh-speed/high-load, or even at part-load?
Thanks for the help!
Brian
Brian
RE: Tuned-pipe / fuel recommendations for OS .30VG(P)-X?
http://extremercmods.com/?page=pipes and use byrons gen2 30% or o'donnels 30% race or speed blends
