Which truck to get?
CT
Which truck to get?
If you had to choose between a revo 3.3 and the lst xxl for a good all around beater which would you go for? Im looking to get back into the spot and back in the day i had one of everything including a 2.5 max and the origonal lst. I know they are both great trucks and the lst seems the be far superior but im looking for a little input.
RE: Which truck to get?
Go LIPO , raw horsepower, go revo, flies like a bird !
http://s240.photobucket.com/albums/f...t=IMG_2343.jpg
MA
ORIGINAL: Devils-Reject
revo, they are tough as hell
LST XXL without a question is the way to go. WIth the right tuning and a gear swap you can easily get 50mph out of em stock, assuming you want or need to go that fast with a monster truck. If you want even more speed you can easily convert the LST XXL to a BL setup using the inexpensiveBL conversion(75 bucks)kit available for the XXL.
ORIGINAL: ntrain42
Maybe if your running on moms carpet surrounded by pillows.
LST XXL without a question is the way to go. WIth the right tuning and a gear swap you can easily get 50mph out of em stock, assuming you want or need to go that fast with a monster truck. If you want even more speed you can easily convert the LST XXL to a BL setup using the inexpensive BL conversion(75 bucks) kit available for the XXL.
NOW I do agree that he should buy the Losi XXL over the Revo as it is a better truck but i'm just saying it is not very inexpensive to go brushless lol
So saying all that I might recommend he buy the Brushless E-Revo and save some money as it is an excellent truck as well and will cost less than a brushless Losi XXL.
