MT on the Beach
NJ
MT on the Beach
im waiting on a tmaxx that is in the mail....
i wanted to take it with us on vacation to the beach in NC.. outter banks...
my local HS guy said if i take it to the beach i will basically need to throw it away when done...
but someone else told me that if i have anodized things. it is like sandblasting... other than that i will kill the bearings... then told to get double sided sealed bearings..
so will i be ok or just dont take it????
RE: MT on the Beach
just rust proof it with silicon spray pb blaster gragrage door lube works great.Goes on than drys you can get it at yourlocal hardware store. Its like 2 bucks ,spray it on every thing even plastic the sand will just fall rite off. When your done bashing just use an air compressor and blow all the sand off,then use wd-40 on the wheel bearings.Dont let people scare you its all in how well you mantain your rig.
