rebuilding an engine...please help!!!
Has anyone ever rebuilt an engine that could give me some advice...i know how to do it but what parts should replce... i know i have to replace the piston and sleeve but what about the connecting rod and crank shaft????
Thanks for the help
Thanks for the help
If this is the first rebuild on this engine and,
You don't race it or it was not damaged the you can just replace the P/S. You should check those items but, more then likely they won't need replacing!
Banned
I just replaced a Piston and sleeve and thats all that seemed to be wrong with it now it runs great. I dont know of anything else that would need to be replaced and its easy
