RC Monster Trucks Discuss rc monster trucks in this forum
problems staying running
Reply
Old 11-24-2011, 07:21 PM
lcplmcgraw1014
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default problems staying running
hey everyone sorry if this is in the wrong place new guy here but i have a problem i just bought a XTM X FACTOR 2 from my boss and it sat up for 2 years i tore the engine down cleaned it out engine seems to be in good shape i did the same with the carb i new glow plug new batteries i got it to run barely and the only way it will stay running is with the glow plug on and throttle held open i have the high spped needle set to factory 4 turns idle is a 1mm I work at a car dealership and the mecahnic said it seems like it not holding vaccum the head gasket might need to be replaced? or maybe the carb is bad just need some help guys thanks in advance happy thanksgiving
lcplmcgraw1014 is offline
Old 11-24-2011, 07:38 PM
1QwkSport2.5r
1QwkSport2.5r's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: problems staying running
ORIGINAL: lcplmcgraw1014
If the engine quits when you pull the glow driver, your low speed mixture is obscenely rich. Lean that low speed needle down 1/4 turn to start with. The glow plug coil gets doused with raw fuel being run that rich and the glow driver helps keep the glow plug lit. That is of course assuming the glow plug is new or near new. If it isnt, replace it. If your fuel is 2 years old too, replace that while you're at it.
Once you get it to run without the glow driver attached, set your high speed needle for max performance first, then adjust the idle/low speed mixture. This is very important.
1QwkSport2.5r is offline
Old 11-24-2011, 08:22 PM
lcplmcgraw1014
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
so this could be why it wont start easy and when it does i have to hold down the throttle im not to sure if it is pulling fuel constent i will try to turn down the needle some more.
Old 11-25-2011, 04:12 PM
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Requiring throttle to get the engine started adds creedance to the rich low speed idea. The main needle (high speed) is probably going to be too rich as well; usually right around 3.5 turns out from seated is pretty close for my climate in Minnesota. Low speed mixture is usually 1.5-1.75 turns out and is a bit rich at that.
Old 11-25-2011, 11:48 PM
1bbcd5
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for this post guys I was going through the same thing
1bbcd5 is offline
Old 11-26-2011, 03:26 PM
lcplmcgraw1014
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks for the quick response im going to try this tonight and post i believe this is going to fix it i think i had the LSN almost closed so im going to open the carb barrel completely and then close the LSN and back it out 3 turns sound about right?
Old 11-26-2011, 03:38 PM
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If the engine has a slide carb, set the idle gap to 1mm. Then lightly seat the idle needle, and I'd back it out 2 turns. I think 3 turns is going to be too rich. I'd set your high speed mixture needle (I call it the main needle) at 3-4 turns out from lightly seated.
What engine are you working with? How much run-time has the engine gotten?
Old 11-27-2011, 02:38 PM
lcplmcgraw1014
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
it is a xtm x factor 2 truck motor is a 24.7 and it wasnt used to much as i said i got it from my boss and we work 6 days a week so it wased used once a day for a few months so i did everything yall said and hook it up and the one way bearing is shot in it now so gotta buy a new one i have a automatic starter should i keep it or go back to the pull start. and no one carries xtm anymore so ill post back in a few
Contact Us Archive Advertising Cookie Policy
