RC Monster Trucks Discuss rc monster trucks in this forum
t maxx carb settings
Old 09-08-2003, 04:16 AM
thedroopster150
Default t maxx carb settings
I just bought a used t maxx with a pull start .15 engine. Can anyone give me a starting point for the low and high speed carb settings or at least what temp the t maxx should run when tuned properly? Thanks.
Old 09-08-2003, 02:54 PM
studysession
studysession's Avatar
Default RE: t maxx carb settings
Did you check the Traxxas web site???
http://www.traxxas.com
I would start there... Anytime it is needle and carb setting I usually always check the manufactures website and if I can not find it then I start asking others... Everyones setting will be different. Depends on climate and environment you run your RC....
Old 09-09-2003, 11:37 AM
jrkessler
Upper end 2 and one half turns out, lower end puts the screw even with the end of the throttle control
