SS wont shift with 18 tooth clutch bell....
VA
When I first put together my SS, I used the 15 tooth bell. I just changed to the 18 tooth bell, and I cant hit second gear anymore. Does anyone have any ideas? Also my truck is starting to run hot. The high speed needle is at 3 and 3/4's out, and the manual says that when tuned in you should be at 2 1/2 to 3. So I'm still running a little bit rich. Help, PLEASE.
VA
RE: SS wont shift with 18 tooth clutch bell....
I forgot, I'm running the HPI power fuel and the original glow plug. Low speed needle is at 1/8th leaner than factory
how many tanks have you run thru it. The savage trans takes time to break in until it shifts properly it almost took mine about 3/4 of a gallon or so. and what is the temps your running at
AL
You probably need to adjust the shift points on the tranny.
He is right. I just swaped motors in mine and I kept trying to tune the motor to make it shift then found out the new motor does'nt turn as many RPM's.
VA
bopper -
First, make sure your motor is tuned correctly, and that your carburetor is fully opening.
Make sure you get a long straight area, preferably on hardpack or asphalt. Apply the throttle smoothly, and listen closely for the pitch change. I have the SS, and my two-speed is shifting very early. Also, it's not a very noticeable shift with the 18T clutch bell because it shifts at a fairly low RPM. You need to listen closely to catch it.
