RC Monster Trucks Discuss rc monster trucks in this forum
kyosho twin force spirit
Old 06-10-2014, 12:06 PM
nitrosportsandrunner's Avatar
My Gallery
My Models
My Feedback
Default kyosho twin force spirit
I just got a Kyosho twin force spirit roller off ebay.
Im hoping in this forum to find some other Force owners.
I plan to try and use a 540 sized 3900kv brushless motor on either 2s or 3s. The goal is to get 25-30mph without high motor temps or having to use 2 battery packs.
Since mine was a brushed truck, I am wondering if I should upgrade the diffs right away? This is only my second Kyosho, the first being an old kyosho 4wd buggy. that wasn't anything special. The twin force on the other hand is a pretty unique MT. Not only does it have the chain drive, but the one way center diff bearing that makes braking and reverse just RWD. Not to mention the unique suspension setup.
Issues Id like help with:
what diffs are available that are an upgrade over stock?
what bodies fit? Im thinking first gen emaxx size?
My front tires will rub the suspension links....I have to set my steering rate to 60%! Is there a way to fix this....is there a way to widen the track?
What parts are most likely to break!!! I know getting parts can be harder than with other brands...so I would like to stock up on a few parts that are most likely to break.
Any one on here do a single brushless conversion on their twin force (1/10 scale system)? If so, what KV was the motor and what size pinion gear did you use?
ID:	2003584   Click image for larger version
ID:	2003585   Click image for larger version
nitrosportsandrunner is offline
Old 06-14-2014, 08:25 AM
The_Shark's Avatar
My Gallery
My Models
My Feedback
Put a single 550 SC system on it from castle, it will push it. Also my mad force nitro rubs on the links too, Just ignore it so long as your endpoints are ok.
These trucks are heaps of fun!
The_Shark is offline
Display Modes
Contact Us Archive Advertising Cookie Policy
