Need body for mayhem st
I Recently picked up a sportwerks mayhem st and it didnt come with a body. Where can i get a new one? Also what other bodies will fit? Thanks for any help
I would say you could use many different styles of body mounts to achieve the right height needed for most 1/8 scale truck bodies to work.
You may have to modify/drill something to get it to work.
I used a LST/Aftershock body on the brushless Mayhem ST Inbuilt for my nephew a few years back. You may be able to fit some of the truggy bodies that are out there but a safer bet would be normal truck bodies from monster trucks. Sportwerks is no longer in business and parts are hard to find, especially consumables like bodies. Make sure your diffs don't have excess play, shim them if they do to make them last because as I said parts are hard to find.
Either way most aftermarket companies like proline list dimensions for their bodies including wheelbase. Towerhobbies.com also list the dimensions of bodies and if you look at vehicles themselves the wheelbase will be listed if you're insterested in a body that came on a particular vehicle.
