E-Maxx Or Other Steering
How can the allignment be fixed on an rc such as an e-maxx. And i dont mean by the throttle or other. I keep adjusting the steering but it still pulls to one side. The rims arent bent neither are the suspension arms... Any Ideas?
RE: E-Maxx Or Other Steering
If you have adjusted the trim...steering linkage and servo horn....then it sounds like you may have a servo going bad. I had a problem with my maxx where it pulled to the right i adjusted the trim and it was fine for a few mins then it would pull again. Turned out the servo was going bad and it keep centering in a diff spot every once in awhile.
