Kyosho FO-XX GP
Moderator
Kyosho FO-XX GP
Not sure quite where to post this, so I'll do it here. Anyone drive one of these things yet? It seems awesome. I guess it's one of those hill climb/puller things, but I'd just love to bash it around in the dunes. Love the solid axle design and the tires.
- Fully factory assembled Readyset.
- Formula off-road body style exudes realism.
- 3-speed A/T makes full use of the power band and is included as standard.
- Shaft and chain 4WD mechanism transfers traction efficiently.
- Includes formidable black anodized side plate chassis.
- Rigid front and rear axles feature robust casing.
- 150cc fuel tank provides long run times.
- Unique design of steering knuckle delivers increased steering angle.
- Pre-painted and pre-cut body with decals applied.
- Solid steel bevel gears equipped on rear diff gear.
- Full ball bearing specifications use 22 bearings through the drive train.
- Low height radio box delivers low center of gravity and effectively protects R/C system from dirt.
- Paddle tread pattern tires provide sure-footed grip.
- 17mm wheel hubs and nuts are compatible with the Inferno series.
- Equipped with large capacity big bore shocks as standard.
- Front - rear interchangeable suspension arms provide efficient maintenance and parts utilization.
- Long wheelbase and low down suspension produces dynamic speed as well as stability in straight line running and cornering.
OH
I have the both the nitro and electric versions. Absolutely fantastic machines. The nitro version is the favorite in my overall fleet. It's durable, handles well, and the engine is reliable. The FO-XX is also very fast and powerful. Can't beat the looks either. Highly recommend it.
