Rustler Vs. Stampede 4x4. Jumping
I was about to order a pede 4x4 untill I had second thoughts on the rustler. Google couldn't find me the answers I was looking for.
Assuming they are both on pede sized 2.8 tires, no gyro, and brushless, what would jump better? A rustler with its low center of gravity or a stampede with 4x4, probably more air control?
Thanks, Ian
Thanks, Ian
The pede 4x4 is going to offer more mid air control due to the 4wd. As far as how they come off the ramp, that depends on the ramp, the spring rates and dampening of the vehicle and the speed it hits the ramp. Out of the box, on the same ramp, they may both come off the ramp the same way but at different speeds. One may launch best at 20mph while the other at 25mph, it all depends on the shock package and the ramp. With either you're going to at least need to change the shock oil, get aluminum shock caps and possibly springs to both launch and land best.
If jumping is all you care about get the pede4x4. More mid air control, more weight to carry more momentum and more expensive stuff to break when you crash land. Have fun
The pede 4x4 is going to offer more mid air control due to the 4wd. As far as how they come off the ramp, that depends on the ramp, the spring rates and dampening of the vehicle and the speed it hits the ramp. Out of the box, on the same ramp, they may both come off the ramp the same way but at different speeds. One may launch best at 20mph while the other at 25mph, it all depends on the shock package and the ramp. With either you're going to at least need to change the shock oil, get aluminum shock caps and possibly springs to both launch and land best. If jumping is all you care about get the pede4x4. More mid air control, more weight to carry more momentum and more expensive stuff to break when you crash land. Have fun
Yeah im doing aluminum shock caps and caster blocks right out of the box, seems like a universal traxxas weak piont
Ive been looking at videos and it seems the 4x4 pede almost has too much air control, and although double front flips might be cool, a rustler can still swing a back flip, and as you said the 4x4 has more driveline parts to break.
Im coming from a bmx background so I have a good understanding of ramp physics.
I wouldnt worry about having having too much mid air control. The videos you're watching may have abrupt inputs, the vehicle may be launching weird, etc. From personal experience I can say that even something with lots of mid air control is easy to control. Launch it right and you won't be making any corrections.
Parts break whenever the limits are pushed, racing, speed runs, jumps. Its when rc is the most fun, it's worth it. Unless the platform is just flawwed, and parts break becase the vehicle is poorly engineered(original maxx) In that case parts are the worst.
I have a 3.3 revo with only a few tanks through it, its been sitting a few years and the engine is no good. I was going to convert it to a e revo bl4s. use it for jumping but I thought it would be too heavy. Traxxas has temporarily held world records for longest jump with 6s e revo though, its probably just laziness that draws me to stampede 4x4 over a conversion project, and half the lipo spending. Think I should revamp the revo?
The only eighth buggies in my budget are the arrma rtr and the base model associated, never really considered either much. Your input is helpful.
Edit: the arrma buggy jumps far and straight but the chassis gets all bent up, no good. Im between the 4s revo conversion or a brushless pede 4x4.
Well I'm a 1/8 fanboy for the power to slide, could care less about jumps that aren't more race oriented. The closest I've gotten to a pede4x4 is a Slash 4x4 and that was too long ago to offer my opinions on. 4s isn't enough for me, gotta be at least 5s. You're probably better sticking with a Traxxas, you'd need one of the higher end buggy/truggy to get a chassis that can take some real abuse without bending.
How many people have really gone gone through the trouble of measuring the exact distance of their RC jumps? 1/8 buggy/truggy fly way better than a Revo and could undoubtably beat its distance. Traxxas were the ones footing the bill so they get the glory, this time.
