messed up diff
WV
RE: messed up diff
Your splernin is probably totally glarked. If I were you I'd go ahead & garnduen the dertitn while I'm at it otherwise you'll end up dewquiping if not gyervxinin the ploarten & then, well, you're f**k*d. Hope this helped as much as the info you provided. Let us know how it turns out!
RE: messed up diff
ha ha that is funny.....not
ok this is what is messit up . it doesnt turn like it did usaly when you turn one wheel the other one turns the other way...... now the both spin freely and i only have Fwd. Se pic that is the part that is messed up...
thx
pat
sorry for the crappy pic. its the cylnder inside the diff case
thx
pat
My Feedback: (158)
RE:messed up diff
LOL, Dude we'd love to help ya but your crappy pic is as bad as you crappy discription of the problem.
Take it completely apart, if the teeth on the gears aren't broken it maybe one of the sheer pins, pull it all apart clean everything and you'll find the issue. It's not Rocket Surgery
What truck or buggy is it out of anyways?
RE: messed up diff
Is it really that hard to describe how messed up something is, or how broken it is without using language that really isn't appropriate for a public forum? I don't mean to be rude, but people of all ages use this forum, and I am sure some think it's cleaver to put asterisks in place of letters, but it does not really change it. Ok I am done with that.
As for your diff. Check to make sure none of the screws that hold the cup to the ring gear are broken. I have sheered off 3 out of 4 of those things. Also check the spyder gears inside the cup. The pin that holds them in could have broken. Make sure none of the teeth are missing. And this time when you put it back together shimming the diff will help to prevent things from breaking in the future. Hope this helps.
Wow I guess you can write in these forums without having to cuss .......
My Feedback: (158)
RE: f**k*d up diff
Pat are you pulling our leg or something, Have you even taken it apart?
ok,
if it's a t-maxx diff
The spool is going to be about $11 gear set $9 your choice
http://www.hobbypeople.net/gallery/634982.asp or
http://www.hobbypeople.net/gallery/636981.asp
BTW, you may want to loosen up your slipper so you don't break it up again, good luck
ok,
RE: messed up diff
You have to at least try to solve the problem before you ask for help!
Try your local hobby store. They will be able to help you much better than we can over the internet.
And.. no cussing please!
ram
ram
RE: messed up diff
What is this? Diff hunting season or something?
I killed mine too:
http://www.rcuniverse.com/forum/Spid...1191337/tm.htm
Damned shaft pinny thingies. Curse them to hell!
I killed mine too:
RE: messed up diff
if any thing i can allwase go back... i found out what the prob is i think.. their is nothing to stop the pider diff from spinning in the housing??!??
pat
pat
IN,
RE: messed up diff
Yeah, spools are for going in straight lines (drag racing anybody?). You definitely don't want that on an off road vehicle. Chances are better than average that you will spin out going into corners. Stick with what you have and limit the diff action by using the right diff oil.
