Loudest Pipe
RE: Loudest Pipe
i had the banana pipe for my savage and it was LOUD!!! they make one for the the tmaxx so try that. i dont get why you would want the loudest pipe.....
RE: Loudest Pipe
All that home made crap is no good for your engine. The Ritter pipe which is now distributed by Racers Edge is the the loudest pipe you can buy. It will give you loads of torque and increases the top speed of the T-maxx 4 extra miles per hour. Thats the banana pipe!!!!!!
CO
RE: Loudest Pipe
i'm running the ritter and i can tell you that when i was tuning in my wasp durring break in i damn near went deaf. it is loud but more importantly its a good pipe, lots of bottom and mids. it doesnt sound like it lets the engine wind compleatly out though (i can't really tell because i havent run any other pipes on it.) the only problem with the pipe is that the combonation of the heat and the fuel makes the paint peal, however i just took a wire wheel in a drill to it and stripped it all off now it has a really cool "factory" look ot it, thats something you can't do with alum. pipes.
RE: Loudest Pipe
A Low restriction homemade pipe produces NO PRESSURE in the feedback line. So make sure you open up the HSN and richen it up a little bit.
And take it easy with the noise. Going deaf is NOT cool.
ram
ram
RE: Loudest Pipe
I run the Ritter on my Savage with a hyper 8 port and the difference in this pipe from the hot bodies pipe is very impressive. Whellies on command, loads of torque and great top end
RE: Loudest Pipe
If u want a loud pipe here is one for you just got it today and man is it loud and it looks cool
http://splatzone.net/~webmaster/pipe.htm
Banned
RE: Loudest Pipe
nothing wrong with home made engiuity at all.
i managed to accidently bash the tip off my pipe today and it sounds a bunch deeper
id go the pipeless option if you dont care about power or ears just tune engine correctly
CO
RE: Loudest Pipe
that pipe looks like a bunch of 1/2" copper tube put together and then chromed, kind of a neet idea if it works, and you could do it at home (without the chrome).
RE: Loudest Pipe
Those afterburner pipes are nothing but bent brass pipes, They Are not desgned for 2 stroke glow engines. They claim how they are designed correctly but I stick with true performance mods of high quality. Not gimicks made in someones garage!!!!!!!!
