Glow plugs
Glow plugs
Anyone with a Force .25 or .26? If so what glow plugs do you use?
I have a .25 - It did not come with a glow plug. Put a brand new OS #8 in it and can not get it to start. Called OFNA and they said those engines will not work with OS glow plugs. Need a longer glow plug. AAUUGGHH!!! If it is not one thing it is another.
So I want to know what everyone uses with these thing?????
RE: Glow plugs
I have a Force .25, I use MC59`s(Break-in), MC8`s(<=20%Nitro) or MC9`s(30% Nitro)...or if you want the best plugs a RB or Novarossi #4(Hot, Break-in) thru too about #7(30% Nitro). I have in the past used a short OS plug with the engine and it has run fairly well, should definately start on the plug!
Stick with the McCoy`s or maybe try a Novarossi for high Nitro extended WOT use
TM
TM
RE: Glow plugs
Well I got it running today just fine. No problems with the #8. Asked a local model shop and they said for the Force 25 and 26 that is all they use is the #8. Today it took me a while but got it to fire up and ran the 1st 2 tanks through the engine.
RE: Glow plugs
If there's a bit of grit in my plugs, it won't glow properly.
Keep it clean.
Most plugs have an unpredictable lifespan.
I keep 3 spare now.
My picco sometimes chews them in a day.
Keep it clean.
I keep 3 spare now.
RE: Glow plugs
ORIGINAL: scale_only_4_me-RCU
What plug did the guy say to use?
I can't believe that statement
The os #8 isn't a short is a standard long plug medium heat plug.
It should work fine with 20% fuel in any engine
Neon - if your getting grit in your plug...or your engine is chewing them your in for trouble !! Having a plug chewed(and the element drop) is VERY bad news for your engine ! It will scratch your pistion and do damage, drastically shortening your engines life. How old is your picco ? how many plugs has it chewed ? They should last at least 4 liters of fuel ! and up to 8-10 liters [X(]
Study, whats it do when it won`t start ? if you pull the plug out does it glow well on the ignitor ? how are you priming the engine ?
TM
