Slipper kit
CA
Slipper kit
I have the T-Maxx 2.5 Robinson Racing double disc slipper kit and i was wondering if you are supposed to use to the pegs that they put on the stock one. I tried to put them in the holes but the pegs are just to big. I tried the slipper kit withoput them already and the pads wore out and now i need new ones. What is the right way to do it. Thanks
RE: Slipper kit
No pegs, that's what the slipper pads replace. What engine are you using? The RRP dual slipper kit is meant for a small block engine. May be possible you ran it too loose?
RE: Slipper kit
I have on on my tmaxx and works great.Try tightening the nut holding unit on all the way and back it off 1/4 turn.Try this it should work if not replaces the pads and adjust as I described.hope this helps. mike
