RC Monster Trucks Discuss rc monster trucks in this forum
fail safe(noob)
Reply
Old 01-14-2004, 12:16 AM
yamahamoto22
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default fail safe(noob)
what is the difference between a fail safe and a servo saver
yamahamoto22 is offline
Old 01-14-2004, 12:20 AM
rcpro-123
rcpro-123's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: fail safe(noob)
uh.......ok a servo saver helps you when you hit soemthing with you wheels so that you would not strip the servo gears inside.A fail safe is when your car loses radio range or when the batt pack it dead.
rcpro-123 is offline
Old 01-14-2004, 10:00 AM
mecky33
mecky33's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A servo saver is a spring loaded servo horn, that allows the steering to give if you hit something with the front wheels that jars the steering. A failsafe, protects your truck from a run away by monitoring the radio signals being transmitted to the servo you have it hooked up to, generally the throttle servo. If the failsafe detects a drop off in signal, it will set the servo at a pre set position, usually partial brake.
mecky33 is offline
