Help!!!
CA
Help!!!
I have a T-Maxx with the 24.7 conversion kit. It starts up fine but when I press the gas it does not move anywhere(it is like it is nuetral). I have already taken apart the gear box and everything seems fine. I also took apart the differentials and those are fine too. I also tightened the flywheel all the way. What is wrong with my car. Any help would be appreciated.
FL
RE: Help!!!
Do you have the reverse module in the truck? Sometimes when I switch between forward and reverse it gets hung up in nuetral. I have to go back and forth between forward and reverse until it catches. I think my idle is too high, that's why it does it.
