RC Monster Trucks Discuss rc monster trucks in this forum
cen mt 2
Reply
Old 01-25-2004, 07:51 PM
d71889b
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default cen mt 2
i was driving my mt2 on the ice and after a while it started making clicking noises.
i dont know whats wrong??[sm=confused.gif]
d71889b is offline
Old 01-25-2004, 08:48 PM
mecky33
mecky33's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: cen mt 2
Clicking noises? does it do it when driving? only when it turns? when you turn the wheels when you arent driving? It could be a diff gear chipped a tooth, the spur gears on the tranny chipped a tooth, a dog bone popping. Give me some more info and we will get to the bottom of it.
mecky33 is offline
Old 01-26-2004, 02:43 AM
nitrobashinauz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i had the same problem, if it only clicks when you steer and the steering is kind of jolty, then you have stripped a steering servo gear. you can either buy a new servo or look for replacement gears for your servo which can be hard to come by. it has striped because you are turning it too hard and too often, and if you are working it that hard (as was i) you may want to get a metal gear servo to prevent this in the future (not that i did). hope this helps,
Lucas
nitrobashinauz is offline
Old 01-26-2004, 04:40 PM
d71889b
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
its not when it turns just when i go more than 5mph it starts clicking.
its not the servo cuz ive already been through about 3-4 servos[:'(]
d71889b is offline
Old 01-26-2004, 04:44 PM
mecky33
mecky33's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What about all of the other things I asked you about? I am thinking it may be a diff gear that is chipped. It should make noise if you just lift it up and turn the wheels by hand if one of the diff gears is chipped.
Also what have you done that you have gone through that many servo's?
mecky33 is offline
Old 01-26-2004, 04:50 PM
d71889b
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yea it makes noise when i lift it up and spin the wheel.
d71889b is offline
Old 01-26-2004, 04:54 PM
mecky33
mecky33's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Where does the noise come from? front, back or middle? does it come from one side or is it centered between the wheels?
mecky33 is offline
Old 01-26-2004, 05:03 PM
d71889b
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
it sounds like it comes from the back-back middle.
d71889b is offline
Old 01-26-2004, 05:06 PM
mecky33
mecky33's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Check your diff cups for a broken cup. If you don not have a broken cup, take the diff out and check your ring and pinion gears for chipped worn or broken teeth. I would just about bet its a diff cup though. These are are an item that fails under normal use due to the lenth of the dog bones. You can switch to CVD's and it should reduce the number of broken diff cups.
mecky33 is offline
Old 01-26-2004, 05:38 PM
d71889b
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
its not the diff cups
d71889b is offline
Old 01-26-2004, 05:43 PM
mecky33
mecky33's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Then its either your diff or a missing tooth on your spur. I was driving on ice in my truck and killed the first gear spur when my clutch bell came loose.
If its not degrading performance though, I wouldn't worry about it to much.
mecky33 is offline
Old 01-26-2004, 05:45 PM
d71889b
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i think its the spur because its worn down alot.
d71889b is offline
Old 01-26-2004, 05:57 PM
mecky33
mecky33's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You can get a new spur on www.ehobbies.com they are like five bucks. I would recommend buying an extra one to keep on hand. I would also recommend a few extra diff cups, an extra clutch, and the screw set. That way you have some spares on hand in case you break something.
mecky33 is offline
Old 01-26-2004, 06:06 PM
d71889b
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i have a bunch of diff cups.
thanks for the help
d71889b is offline
Old 01-26-2004, 06:08 PM
d71889b
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
do you know the part number for the spur gear???
i cant find my book that shows them
d71889b is offline
Old 01-26-2004, 08:05 PM
mecky33
mecky33's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
go to www.toyhaus.com and use their interactive parts finder. I still recommend ordering from www.ehobbies.com though. Toyhaus charges a lot for shipping and they charge more for parts. Good luck with the swap and let us know if you have more questions.
mecky33 is offline
Old 01-26-2004, 09:12 PM
d71889b
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks for the help
d71889b is offline
