RC Monster Trucks Discuss rc monster trucks in this forum
OIL FOR INTEGY SHOCKS
Reply
Old 01-30-2004, 05:44 PM
tegwin
tegwin's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default OIL FOR INTEGY SHOCKS
What is the best weight oil for Integy piggy back shocks on a savage, i want it for bashing, but the 5 weight oil i have in their at the moment is s**t.
tegwin is offline
Old 01-30-2004, 05:49 PM
mecky33
mecky33's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: OIL FOR INTEGY SHOCKS
I have integies on my MT2 and put some heavier springs on it and one of my LHS's recommended 35 or 40 weight with the springs I put on. The oil really depends on how heavy of a shock you are using on it. The heavier the spring, the lighter the oil and the lighter the spring the heavier the oil.
mecky33 is offline
Old 01-30-2004, 05:51 PM
jefx
jefx's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I thought it was the other way around.
jefx is offline
Old 01-30-2004, 05:54 PM
mecky33
mecky33's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
jefx, if you run a light spring and light oil your truck will bottom constantly and if you run heavy shocks and heavy oil there will be no give in the suspension.
mecky33 is offline
Old 01-30-2004, 05:55 PM
jefx
jefx's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, but if you run a heavy spring and light oil, it'll be too bouncy.
jefx is offline
Old 01-30-2004, 05:56 PM
tegwin
tegwin's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
jefx, ur wrong.
mecky33 has some common sence, lol
thanks for the adice.
i am running the stock springs on the igy back shocks, what oil would you use??
tegwin is offline
Old 01-30-2004, 05:59 PM
mecky33
mecky33's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you run a really light oil. I have the trinity dual spring rates on the back of my MT2 and standard Integy springs on the front. and the guy I talked to said to start with 35-40 weight and go up or down from there to fine tune it. There is no definite weight to run with any spring/shock combo. It ends up with personal taste for handling and suspension behavior. But 35-40 weight is a good place to start and go from there. But back to what we where discussing, If you run a 10 weight oil with a .50 spring, then you will have a bouncy ride. there is a limit on how light of oil you should run with heavy springs.
mecky33 is offline
Old 01-30-2004, 06:02 PM
tegwin
tegwin's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My truck was second hand when i brought it and all the shocks are not the same compression.
Would it be a good idea to take them all appart and straigten all of the piston rods and clean them out and re-fill them
And how do you get the top of the integys? (what tools)
tegwin is offline
Old 01-30-2004, 06:03 PM
jefx
jefx's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Why am I wrong? The oil is there to slow down the spring, it's called dampening. If you run a heavy spring and light oil, the shock will bounce back too quickly, giving you a trampoline effect. If you run a light spring with heavy oil, the shock will be to slow and not soak up any bumps. You have to find a happy medium, but I thought that the heavier the spring- the heavier the oil and vice versa, within reason.
jefx is offline
Old 01-30-2004, 06:05 PM
mecky33
mecky33's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Integy's will just unscrew by hand if you squeeze them hard enough. Also, instead of bending the shafts back, its like five bucks for two new shafts. I just bought a set for my truck. Yours would be a little more for eight of em, but they will work better in the long run. Also, you may not want to be so rude to jefx, he is very smart when it comes to RC stuff. And we are always learning new things. I have learned a few things from jefx.
mecky33 is offline
Old 01-30-2004, 06:08 PM
jefx
jefx's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you Dan. If you guys know something that I don't, then I'm willing to be swayed. I was just stating it as I understand it.
jefx is offline
Old 01-30-2004, 06:13 PM
tegwin
tegwin's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i was only joking, its quite late here in the UK and sleepy people dont ususaly say what they mean, or mean what they say.
Where do you get shock rods from?
i apologise if i insulted anyone
tegwin is offline
Old 01-30-2004, 09:30 PM
twinmania
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I will have to agree with jefx. After a few research in articles and magazines (Car Action February Issue). It also states that you should use stiffer springs for heavier weight oil and vice-versa.
twinmania is offline
Old 01-30-2004, 10:06 PM
mecky33
mecky33's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Twin, if you think about the heavy spring heavy oil then you run in to a problem of no give. the shock slows down the travel of a suspension arm. The spring works to counter-act gravity and return the arm to its original position. If you put a really heavy spring on the arm their will be less movement due to a higher counteractive force. If you add to that a heavy shock oil that provides heavy damping you will get no give in your suspension and it will cause a very rough ride, forcing the tires to take all of the impact. This is great for sports cars where you don't want the suspension moving all over the place. In MTs you want the exact oposite, you want as much suspension movement as possible. Thus the heavy spring, light oil an vise-versa.
mecky33 is offline
Old 01-30-2004, 10:07 PM
popa71
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Integy springs are very stiff I ran the 25 weight oil and they were great. Although in a rc extreme review they recomend 20 weight. If you run the heavy oil they are very bouncey on bumps and jumps because they are not getting enough compression.
popa71 is offline
