RC Monster Trucks Discuss rc monster trucks in this forum
GEAR RATIO HELP
Reply
Old 02-05-2004, 06:53 PM
azrctruck
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default GEAR RATIO HELP
I wanted to play a bit with gear ratio on my MGT and savage. correct me if I am wrong to figure out your gear ration you take the spur gear and divided by the clutch bell for example on a stock mgt 52t/15t ratio 3.46. I am aware that this is not the final gear ratio to the wheels. So i am assuming that the lower the ratio the more top end speed the higher the ration the more low end. so if I went to a 52t/16t ratio 3.25 would give me more top end. so with that said what are valid spur gear / clutch bell combination for the MGT
azrctruck is offline
Old 02-05-2004, 11:47 PM
cid
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: GEAR RATIO HELP
page 15 in your MGT user guide will tell you every thing you need to know about gear ratio in the Mgt
cid is offline
Old 02-09-2004, 04:38 PM
azrctruck
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
page 15 also shows a lot of spur gear and clutch bell combination that are not valid just try to install a 15/46 was not able to line up the engine
Old 02-09-2004, 06:11 PM
cid
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
that may be true but you can get the same ratio with a 16/49 both work out to a 3.06
cid is offline
