Glow plugs?
MS
Glow plugs?
Whats the difference between a hot, cold, and medium glow plug???
i guess you would use a hotter one for winter and a colder one for summer, but i really dont know
RE: Glow plugs?
A colder plug is used for lower content nitro, and a medium for mid nitro and hot is used for high nitro content. In some cases, you would use a colder plug with a larger engine and higher nitro. The heat of a plug is pretty much the timing system in a nitro. The hotter a plug the sooner it will detonate. If you get to hot a plug in your system it will cause predetonation and loss of power, ulitmately ruining an engine.
MS
RE: Glow plugs?
so for lets say.... the Genesis im gettin with a .46 engine, that im probably gonna be running 20% nitro in i should use a cold or medium plug... right
