Monster B4
FL
RE: Monster B4
ORIGINAL: Smokinjoe6450
Got to fooling around and "beefed up" my B4........I know it's not a big deal but I am bored.......
btw do you race you B4? If so I have some questions for you.
Greg
RE: Monster B4
OMG thats something a fool would fall for man no afence but that buggy just has big tires and shocks.
Get over yourself.
TN
RE: Monster B4
not possible to put the tires on the tc3 or NTC3. ive got the savage 25 and the NTC3. if you were able to it would strip the gears or wear down the clutch. and you would have no speed.
FL
RE: Monster B4
Ya Mt2s are awesome I just got home from running it this morning.
What esc/motor combo are you using for b4?I was thinking about getting one for racing in the stock class.
RE: Monster B4
I have the Novak Dually ESC, and I run the 19T Chameleon 2 Pro (spec class). It really handles well with this motor. They work well together. If I run modified, I use the Speed Gems Pro 15T. The 15 turn has alot of punch to it. It really gets the B4 moving out of turns well w/o overkill. I also have an 11T but it is to fast for a tight track. If you have a track where you can open it up...I would suggest the 11T As far as stock....I don't have a stock motor so I can't help you there. Sorry. I do recommend the 19T class if you have one, a little faster than stock but not crazy!!!
I am in the process of taking apart my MT2 and stripping my chassis, re-painting and putting back together. I always end up w/ extra screws................................ [:'(][:'(]
FL
RE: Monster B4
Im wanting to get into stock or 19t racing i cant decide if I should get the rtr or kit.the kit with all the stuff neded comes out to be about $60 more and that is money I could be using on a nice stock or 19t motor .Did you get a rtr?
Ya I hate rebuilding my mt2 I do every day after running it.I built a small track in my backyard that I run on.I keep breakign body posts and mounts someone needs to make alum. ones
RE: Monster B4
I traded for my B4, but I already had all of the electrics.
The body posts suck on the MT2. I finally got tired of ordering and fixing them so I got the body mount that traxxas uses on the rustler and mounted it onto the chassis (direct fit) Of course the holes on the body don't line up so you have to drill new ones, but it doesn't break anymore!!!!
FL
RE: Monster B4
Ok I think Im going to roder the rtr and a new motor unless I can find one in the classifieds.Thanks for your help.
I may try the rustler body mounts but do they have the udjustable posts?
Thanks again
Greg
Thanks again
Greg
RE: Monster B4
they are not adjustable posts but you can get different heights. They go on w/ a screw in the bottom. (its alot easier than adjusting the mt2 mounts)
