RC Monster Trucks Discuss rc monster trucks in this forum
JUMBO KONGS'S
Old 02-10-2004, 10:24 PM
kevk25
Default JUMBO KONGS'S
DOES ANYONE OWN THE JUMBO KONGS, AND IF SO WHAT ARE THE GOODS AND THE BADS OF THEM?
Old 02-10-2004, 11:38 PM
spazzyfry123
spazzyfry123's Avatar
Default RE: JUMBO KONGS'S
The goods-they make your truck look freakin huge. They will probably drive through anything.
The Bads-They look bogus. You will have to have a serious servo to steer them. They might put too much stress on the engine and reduce its life. Expensive.
This is probably not the best post on here, but that's all I have towards Jumbo-Kongs.
Old 02-11-2004, 12:08 AM
jefx
jefx's Avatar
Bads:
Your truck will be very bouncy.
It will have a higher CG.
Jumps will be harder to land.
Steering ^ like above.
Weight.
You'll need to do some major gearing work.
Goods:
Higher ground clearance.
True to scale look.
Old 02-11-2004, 02:56 AM
caseyddr
My Feedback: (13)
caseyddr's Avatar
ORIGINAL: jefx
Bads:
Weight.
Goods:
True to scale look.
If your buying the jumbo kongs your not worried about your jumping abilities or higher CG. Personally i wouldn't mind a pair assuming I had a big truck in the first place, and most ppl have hi torque steering servos in MT's anyways.
As in major gear work lol, jus drop a CB a few teeth lower and your fine, thats not major.
Old 02-11-2004, 08:08 AM
paperclipracer
i don't like them from what i seem you have no control
Old 02-11-2004, 08:36 AM
miserynitro
My Feedback: (8)
i think they would be kool, and if i had the $$$ i would buy them. Use a 13T or even a 12T bell, and most people have upgraded motors, example, hyper 8 port, Picco .26... ect. and if those engines can't handle that.... then nothing would.
Old 02-11-2004, 09:55 AM
kevk25
Cool thanks for the replys, you made my mind up tho, im not getting them, really not into replaceing a whole bunch of stuff yet to get it to handle right.
Old 02-11-2004, 12:05 PM
jefx
jefx's Avatar
Your right, it's not exactly major to change the clutch bell and spur. I was implying that it may take you several attempts to find a suitable gear combo. If it does take you a few attempts, then that means disassembly and reassembly over and over, which becomes more of a major job. Plus the increased rotational mass of the jumbo's will be harder on the entire drivetrane and braking system.
Old 02-11-2004, 12:07 PM
caseyddr
My Feedback: (13)
caseyddr's Avatar
ORIGINAL: jefx
agreed thats when you would need a hitorque servo jus for breaking! Lol
Old 02-11-2004, 12:46 PM
SH ByA
SH ByA's Avatar
With that much rotating mass and the added weight to the truck, like JEFX said, you will need serious breaking ability. once that gets up to speed it will be a Biotch to stop. and that is something to concider.
