EK-4 S2 Vs. RCX
EK-4 S2 Vs. RCX
Hi, ma first post...
a coupa of question'z...
is that EK-4 V2 Same as that EK-4 S2? same truck exacly?
Whats better..(speed/Grip/Rock Climbin...)
Kyosho MAD FORCE RCX?
Thunder Tiger EK-4?
Thx.
oo...
Whats better for me to get as my FIRST monster truck?
Thunder Tiger EK-4?
Thx.
oo...
RE: EK-4 S2 Vs. RCX
TK20, the EK-4 V2, is basically the same truck with emphasis on the V2 being the key. The V2 equates to "Version 2", which has the upgrades that the earlier version did not. If you are looking to buy an EK, just make sure it's a V2. Even tho the V2 has the upgrades that the earlier version didn't, there is still room for considerable aftermarket upgrades. Hope this helps.
As for rock climbing, I'd go with the Mad Force. The EK isn't geared for it, plus the ground clearance isn't there, nor is there any articulation and it would require major re-designing to gain the necessary articulation. For speed, the EK with a 2-spd should be able to get 50+mph!
RE: EK-4 S2 Vs. RCX
Go with the Mad Force im not saying that the EK4 is a bad truck but the mad force is a bit easier and it has a pullstart.
Plus the engine in the RCX is a os21 rg-x(p) its an quality engine.
But if it is power your after then the ek is better but its harder to start.
RE: EK-4 S2 Vs. RCX
madmaniac, I agree going with Mad Force, 'specially for rock climbin'. As for the EK, it's NOT harder to start than any other engine. I had an EK a couple of years ago and it started most every time within a few seconds. I still have this engine and it's mounted in Pie Wagon. The only difference in this engine is that it's ringed, which will require a whole different break-in procedure. Other than that, it's an excellent engine and reliable...IF it's mantained.
RE: EK-4 S2 Vs. RCX
I also had an EK4 about 1 year ago and i wasnt to happy with it.
It was just to much to carrie with you when you started it.
I mean a 12 v battery and a big rotorstart just to much to carrie with you.
RC Jack your pie wagon is cool i really like it nice work
RE: EK-4 S2 Vs. RCX
ORIGINAL: madmaniac
to much to carry huh...ever try carrying al ther gear assoiciated with rc aircraft...bnig 12v batt, starter, starter box, jug o fuel, pump, spare parts(lots) assorted tools, and wiores out the ying yang..plus the fuse and wing...come on man suck it up...it aint that much to carry...if it is ure in the wrong hobby...
RE: EK-4 S2 Vs. RCX
I paid 1100$ for my ek 4 with all the accessories thats expensive but i live in Sweden all rc stuff is expensive here[:'(]
RE: EK-4 S2 Vs. RCX
what kinda 12v u runnin?? i good ol car or truck battery should work without problems..mines been goin on for about a year without rechargin...and we fly our planes every wknd usually puttin 6 or flights in a day each with 3 planes...i dunno maybye i have a good battery or sumthing is shorting out ures..i dunno
MD
RE: EK-4 S2 Vs. RCX
I'd go with the RCX. Kyosho makes quality vehicles and I've heard some not-so-nice-things said about the EK-4 by some owners who are my friends. Getting parts will be a problem with either truck though.
Scarab
Scarab
RE: EK-4 S2 Vs. RCX
Getting parts isnt my problem.
i can get parts for the ek-4.
i dunno about the RCX.
Thanks.
but does any one own one around here?
the suspention is weird, can it take a bump on on side of the truck without lifting the wheel from the otherside?
Thanks in advance!
Thanks.
Thanks in advance!
My Feedback: (8)
RE: EK-4 S2 Vs. RCX
Have you thaught about taking the starter probe out of the cone and installing the starter probe on to a cordless drill. Works perfect and it frees up a hand to put nicad on
MI
RE: EK-4 S2 Vs. RCX
madmaniac Date 2/28/2004 2:33:42 AM
i have a mad force and the suspention is good its a great truck.
Heres some pics of my truck
IL
RE: EK-4 S2 Vs. RCX
ORIGINAL: Gordon69
Mad Force suspension just dont have enough suspension travel to be any good. The 1 peice accel limits the travel.
REAL MONSTER TRUCKS ALL HAVE SOLID AXLES, so it's everyone else who's 'wrong' by calling independent susp. trucks "monsters"!!
And while TRAVEL isn't as big, ARTICULATION is much better (those pics where 3 wheels are planted and one is on top of a beer can...THAT'S articulation!) which is why pretty much ALL rock climbers are solid axled!!
I for one have no interest in rock climbing, but that's me. I also think the MadForce is overpriced (my god, I JUST saw a used RCX on consignment at my LHS for $1400...what the hell could he have done to it??).
So you really can't refer to this truck in any way as not "any good".....there are lotsa rock climbers who could say that about YOUR truck....and they'd be correct!!
Dean
RE: EK-4 S2 Vs. RCX
is it possible to mount bigger wheels and tires onto ek4? are there some between 7 and 8 inch???
because the ek4 hasn't got so much ground clearance
RE: EK-4 S2 Vs. RCX
Finding anything for my EK-4 is not easy. I broke a wheel and my local shop owner ordered a new set of stock ones for ACE along with many other parts that I needed like rear wheel bearings that are 8 by 16 mm and the rear ones need lots of checking. The only set of wheels that I can find are from Ofna that fit there Dominator but they have a one inch off set from the center and have fun trying to turn it. just get some lower profile tires if you can find some. I just use the stockers because they fit. wo
RE: EK-4 S2 Vs. RCX
For what it's worth I have found a way to start all my trucks and cars. I use a 12v 175 am lawnmower battery and a 1/2 incn drill with and inverter and shaft starts systems. Even my EK-4 starts in seconds with this system. Yes it is a lot to throw into the back of my pickup but it starts anything and quickly. wo
