need help
RE: need help
Does it rev up and die or does it just kinda sputter out? If its sputtering out, then your HSN is to rich. If its reving up really high and dying, then its to lean. If you run it and come back down off the trottle and it dies, then your LSN (if equiped) is to rich. It could also be an air leak, but I would suspect the tune since its new. Make sure you break it in before you drastically change needle settings though.
