whats wrong?
whats wrong?
i was running my savage and when i press the throttle most of the power from the engin like 90% of the power goto the front wheels, the rear stll spin but very little. the front spin so fast it juss skids. what do u guys think is wrong? pls help.
TN
RE: whats wrong?
spin the rear wheels with the truck off the ground. then see if the front wheels spin. if not your missing a pin connecting the drive cup to the shaft. there are 2 drive cups in the rear. it will be one of them most likely. otherwise it could be something else. check that first. then report back to us.
RE: whats wrong?
no all the cups are connected i tried locking the dif with the screw in the diff and now it works but my rear diff is locked...is that an ok fix?
