towerhobbies
RE: towerhobbies
Shipping depends on weight, size of package & where it's going. When you order something, not just from Tower, but, any place, you'll get a shipping quote before you submit your order. You could even call Tower with your order and they'll tell you the shipping charge. This should help.
TN
RE: towerhobbies
yea, if you are a member, ground shipping is 3 dollars. if you arent, it cost like 7 dollars. and for shipping a air filter ground, it will be there in 3-4 days for ground shiping. i normally get mine in 2-3 days but i live not so far away from them (less than 500 miles).
Banned
RE: towerhobbies
viza, if it is considered under "parts", they only charge $3 for shipping. He said he is just ordering an air filter, so it would be $3.00 shipping, in the 48 states. But as the others said, the normal shipping charges when you buy more or other merchandise (cars, planes, etc), the shipping will vary on your location.
Banned
RE: towerhobbies
If all you're ordering is the air filter, and you're using Ground Mail, then yes. Go on, use the "BUY NOW" icon, ebter your address, and it gives you the total amount and your shipping options....it takes no more than 2 minutes, less time than it took to make this thread
RE: towerhobbies
NV
RE: towerhobbies
I just ordered 8 item off the "parts express" list and the shipping and handling was $3.99. normal shipping is $7.99. if you are a member of the "Super Saver Club" the $7.99 is waved if order is over $150....
Banned
RE: towerhobbies
ORIGINAL: Bush Wacker
No its $6.99 I just ordered some dogbones from there last week.
