Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Monster Trucks
Reload this Page >
Mega Force - No reverse! Help needed...
RC Monster Trucks Discuss rc monster trucks in this forum
Old 03-18-2004, 04:37 AM
witchmaster
witchmaster's Avatar
Default Mega Force - No reverse! Help needed...
Hi, recently bought a Kyosho Mega Force, but now I realise that the reverse is not working. The engine only speeds up without the car moving backwards, have I forgot something?
Thanks in advance!
Old 04-07-2004, 03:41 AM
bluntwrap
Default RE: Mega Force - No reverse! Help needed...
hi, if you take the qrc apart you should see a thing which slides back and forward as you move the throttle servo. When you accelerate the thing in the qrc should slide away from the brake and connect with a gear to make it move forward. When you pull back on your radio the servo should pull the thing which slides, towards the brake. This connects to an extra gear which makes the whole drivetrain move backwards.
Check the pin in the thing that slides still gets pushed in the groove which make it move.
