RC Monster Trucks Discuss rc monster trucks in this forum
TRUCK WONT IDLE!
Reply
Old 04-05-2004, 02:04 PM
sn0wrider
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default TRUCK WONT IDLE!
WHY DOESNT MY TRUCK IDLE!!!!i started it a few days ago, then i tried the past few days, OK i prime it till i c the fuel go in, then 1 more time to get it in the engine, then i put the glow starter in and turn it, then pull, it idles for about 5 seconds then shuts off, then why i try and start it again it gets flooded every single time!
sn0wrider is offline
Old 04-05-2004, 02:16 PM
mecky33
mecky33's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: TRUCK WONT IDLE!
It sounds like it is running rich, lean out the high speed needle an eight of a turn. Depending on weather you will constantly have to retune the engine to get it to start and run. Also you may need to lean out the high speed up to a half a turn until the engine starts to warm up then you can richen it back up.
mecky33 is offline
Old 04-05-2004, 02:18 PM
ThermalRD
ThermalRD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How old is the glo plug? You may need to replace it. Even if you plug still lights up, it may not be as hot as it was when you first got it. So try a new plug. Make sure your idle is set properly, and see how it runs. Aftermarket heads can cause motors to run TOO cold, making it hard to start, and hard to idle. So, be careful of that. What motor are we talking about, and what vehicle? Fuel content? plugs? how long have you had this motor?
Matt
ThermalRD is offline
Old 04-05-2004, 04:08 PM
sn0wrider
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i just got my tq about 3 weeks ago...i was out a bit ago and got it to idle for 15seconds, thought it was good, then it dies...i tried everything, leaning it out, turning the idle screw, EVERYTHING!
Old 04-05-2004, 04:31 PM
mecky33
mecky33's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
When it dies is it revving up and dying or is it sputtering and dying? And did you try a new glow plug?
mecky33 is offline
Old 04-05-2004, 04:44 PM
ThermalRD
ThermalRD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Slow down man, take a breath, and lets figure it out. You said you tried everything, leaning it out, turning the idle screw, everything...Well, define everything. How is the truck running, and did you change the glo plug yet? Was the motor tuned, and this just all of a sudden happened? or has the motor been in break-in during this time?
Matt
ORIGINAL: sn0wrider
Old 04-05-2004, 06:19 PM
sn0wrider
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ok i fixed it, needed a new battery[:'(]..but now it overheats really easily..some1 said to richin it up, how much should i turn clockwise(right)?
Old 04-05-2004, 08:10 PM
ThermalRD
ThermalRD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
NO! If you turn the needles clockwise, that will LEAN it. Counter clockwise richens it up.
Matt
ORIGINAL: sn0wrider
