OS .21 RGx
OS .21 RGx
Anyone know an online source for manuals for this thing? The Kyosho MF RCX manual SUCKS bad, and doesn't cover the RGx very well. I dialed in the high speed needle well, but the low speed is baffling me a bit. Thanks!
Or, if someone has the manual could scan the midrange needle tuning page and default needle settings and send them to me or post them? I know it is a lot of work, but I would REALLY appreciate it.
RE: OS .21 RGx
if its an OS engine you could go to there website and look at their online manuals
http://www.osengines.com/manuals/index.html
YT, BOTSWANA
RE: OS .21 RGx
Your RG has a 3 needle carb? Mine only has the HSN, and LSN. Thats odd.
Matt
Matt
ORIGINAL: Dale Gribble
RE: OS .21 RGx
three adjustable controls are provided on this
carburetor.
CARBURETOR CONTROLS
The Needle-Valve: For adjusting the mixture strength when the throttle
is fully open.
The Mixture Control Screw: For adjusting the mixture strength at part-throttle
and idling speeds, to obtain steady idling and
smooth acceleration to mid speeds
The Throttle Stop Screw: for setting the minimum idling speed
carburetor.
CARBURETOR CONTROLS
is fully open.
YT, BOTSWANA
RE: OS .21 RGx
Yes, low speed needle, high speed needle, and an idle screw. No mid range needle.
Matt
Matt
ORIGINAL: voodoo
carburetor.
CARBURETOR CONTROLS
is fully open.
carburetor.
CARBURETOR CONTROLS
is fully open.
RE: OS .21 RGx
Man Voodoo, you are da bomb!!! Thank you thank you thank you for that link to the manual.
Serious, I searched OS engines, that same website for 20 minutes and couldn't locate the manual.
Oh, Matt, I am sorry about the miscommunication. My issue was dialing in the LSN... Just a slip to call it mid range needle. You were right. Even bug exterminators make mistakes every now and again.
