cen fun factor mt2 tires/wheels
hello all, can someone tell me the tallest tires i can put on my mt2 ?
and do i need wheels/ wheel adapters?
mecky33 had shown somone some wheel adapters. but i dont know what i need.
will tmax tires and wheels fit using these adapters without rubbing?
http://www.renegaderc.com/shop.mv?Sc...t_Code=RCP1002
PS: i just BIG tires LOL.
RE: cen fun factor mt2 tires/wheels
the MT2 has a standard 2.2" tire size, i know the Mashers fit, but they lower the hieght
just get some foam, for the stock tires, and your sweet
ok, but the wheel offset is what i worry about (depth). if the wheels are not the right offset, there bound to rub.
thanks, for the foam idea.....
Yenko, 2.2 wheels/tires are all going to give you a similar ride height, you will need to get the wheel adapters to go to a larger wheel and tire. You will lose a little acceleration with larger tires, but if you go with the offset T-maxx wheels you will gain some stability.
i would like to use these, even if there on the truck just some of the time.
IMEX Jumbo Kong Complete Tire Set (Sayville Chrome) - IMX 7500
would these fit my mt2 with the wheel adapters.
but, after measuring i think they would rub eash other LOL !
well i guess that would make for a great mod, just building a bigger chassis.
and swap for a bigger engine, and install those tires ...
With the adapters those would fit on the axle. But I dont know how they would turn. You would definitely need a metal gear high torque servo and a 6V hump pack. With as big as those tires/wheels are, unless they have some serious offset, will rub the frame. I would stick with standard T-maxx tires and the offset wheels recommended with the adapter kit. But its really up to you what you want to buy. As far as a larger frame, it can be done. But cost is what has kept a lot of aftermarket manufacturers from making them.
