RC Monster Trucks Discuss rc monster trucks in this forum
run it till its empty
Reply
Old 05-09-2004, 06:50 PM
panhandeler
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default run it till its empty
i think this has been asked before but is it healthy to run a nitro rc car till the engine cuts of cause of no more fuel in the fuel tank?
panhandeler is offline
Old 05-09-2004, 06:59 PM
RCFreakInFL
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: run it till its empty
When you run a tank out with the motor, you are leaning the motor out, which can cause serious damage, and definately shorten the lifespan of the motor. My suggestion, would be to stop the engine at the flywheel from underneath the car, with your finger....or some other foreign object. My second suggestion, would be to just plug the exhaust with your finger, the only problem with that, is it can put unnecessary backpressure on the motor.
Leaning out the motor with an empty tank, is definately not on my list, of how to stop my R/C
RCFreakInFL is offline
Old 05-09-2004, 07:23 PM
Bush Wacker
Bush Wacker's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I did that once I had a round burn on my finger for 3 weeks.
Bush Wacker is offline
Old 05-09-2004, 08:00 PM
nitromacguyver
nitromacguyver's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
but its the same thing as pinching the feul line, isnt it? also when your done bashing your supposed to start up the engine to burn out the fuel in hte lines and carb to prevent it from combining with the miosture and causeing corrosion. i dont think theres any thing wrong w/running the tank dry but thats just MHO.
nitromacguyver is offline
Old 05-09-2004, 10:27 PM
chase044
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
it is ok to do.it willonly run the engine lean for about 5 sec. its not running lean very long.
chase044 is offline
Old 05-09-2004, 11:38 PM
xtm
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
as long the engine isnt overheating it is fine , makes for a easier startup next time I also us afterrun after usen this method if I am done for the day
xtm is offline
Old 05-16-2004, 10:39 PM
rdmonster
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
When mine gets real low and starts to lean out I just go easier on it. If its real close and hasn't died yet ill tip the truck in the direction of the fuel pickup to get the last of it out. If i dont have that much time ill suck the rest out with the filler bottle and then let it die.
rdmonster is offline
Old 05-17-2004, 07:11 PM
jkdv8
jkdv8's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
As long as your not redlining it when it runs dry. I usually let mine idle till it runs out then do the after run oil thing.
jkdv8 is offline
