trx 2.5 question
RE: trx 2.5 question
ORIGINAL: BIG BOYZ TOYZ
DON'T WASTE YOUR TIME !!!!!!
TRX 2.5 IS A VERY FAST ENGINE BUT IT WILL NOT HOLD IDLE EVEN AFTER THE RUN IN .
I OWN A T-MAXX AND I'VE CHANGED 3 ENGINES ALL OF THEM HAVE THE SAME PROBLEM.
FORGET IT !!!!
DO NOT WASTE YOUR TIME TUNING .
SWITCH TO A SIRIO 18 OR PICCO 21 MEDIUM BLOCK. OR IF YOU CAN PAY MORE SWITCH TO A XTM CONV. WITH 24.7.
SORRY TO UPSET YOU BUT THIS IS THE FACT
FORGET IT !!!!
The other day my 2.5 cut out for the first time in over a gallon of fuel. It had been running so well I couldnt believe it. OOPS it ran out of gas. I think you need to spend more time learniing how to tune the 2.5 because this engine is pretty good!!!!!!!
ORIGINAL: ThermalRD
Well there you have it, those are the FACTS! lol. Go easy on the caps man. Both 2.5 engines i have run and idle exceptionally well. I'll admit the 2.5 is picky to tune. Once you get it, its gold. The 2.5R is alot nicer, and never gives me any problems. Just be patient tuning, and you'll get it. Sounds like big boy has 3 engines he doesnt know how to tune.
FORGET IT !!!!
FORGET IT !!!!
PA
I've tuned alot of engines over the years , some cheap some not-so-cheap but NONE of them ever gave me the headaches that the 2.5 did. The only way I would have another one would be if someone gave it to me , then I would put the hammer to it too. Also to rccars411 Yes I think the madforce rocks once you get a few small bugs worked out, and the twin I made into a crawler(too many mods to list , I don't want to jack this guys post)
#31
ME
when engines are 100 bucks, you get what you pay for. the mach .26 and the .15 maxx are both cheap. and cheaply built compared to the 300 dollar engines. screw it. run them till they die. drop a hundred bucks and get r done!! i beat the crap out of all my engines. i got like 6 or 7 gallons out of the t-maxx engines. then i threw them. as soon as they lose compression there in the trash. dont know about the mach yet im in the first gallon. but i will do the same if it lasts 7 gallons.
