Official Kyosho Mad Force Thread
#76
NC
RE: Official Kyosho Mad Force Thread: Help!
ORIGINAL: Mad Racer
I thinking of getting a enslave mad force too, not sure yet. I used to owned a kyosho mad force, but I sold it. On ebay, it says that it could go up to 60+. Is this true?
It won't run 60mph, but I bet it's fast for a RTR. The speed claims from the more reputable companies like Traxxas are far fetched enough, but the companies that make all those knockoffs get really stupid with their claims. The Mad Force is a fairly lightweight truck with a nicely geared 3 speed transmission. Even with my weak little Kyosho GS.21(kit version) the thing wheelies very easily and has a decent topend too. If that .28 runs like a decent sport .28 should, then the Enslave is a fast truck.
The problem with the Mad Force isn't the truck itself, but rather the replacement parts for it. Where do you get Enslave parts? I guess I better start hitting ebay more often and stocking up on MF parts, cause now all the Enslave guys will be plucking them up...[]
You can always go through Kyosho Americas overpriced Shopatron website
#77
Location: Bakersfield CA now watford UK, UNITED KINGDOM
I have the enslave but I have upgraded all the week parts with Kyosho upgrades all are exact fit the first thing I would upgrade is the tires the enslave ones are really hard.
#78
ORIGINAL: guy4x4
Ya the header looks like it don''t have a good seal I have another header lying around so i''m going to put that on and buy a xtm pipe like I have on my MGT.
xtm mt exhaust and header
kyosho option part engine mounts with xtm 457 3.8 hp engine
with kyosho special flywheel and cut pilot shaft to allow mad force standard pilot shaft to screw on
kyosho megaforce rims with imex roadhawg tires
new era extended chassis with full set of new era dogbones front, rear and in axles.
new era rear lockout braces
thundertech eliminator steering kit with steering servo from associated mgt 8.0
4 shock conversion
alloy braces in wheelie bar with 1" rubber wheels
4 spyder savage diff gears front and rear
500k diff oil
#81
The front and rear axles are the same width, the only difference between the two is that the rear axle has a hardened ring gear fitted to cope with the load of continious wheelies
as for the width its 12" outside hex to outside hex hope this helps
#82
Dang it. I ordered the RC4WD alumi last week assuming it was same length as the X-Factot ( 14" ). Looks like I'll be runnen spacers now. Anyone have these alumi axles and can tell me how strong they really are????
#83
Well, since we are posting Mad Force goodness...
Here was my first Mad Force RCX... What a fun truck it was. I sold it and regretted it.
Then years later, I found another RCX and I don't intend to get rid of it. Its a shame Kyosho discontinued the Mad Force.
#84
ORIGINAL: Dale Gribble
#87
O yeah! official mad force thread!!! keep it up! mad force rocks!
my force!
specs:
Lrp z.28r spec3
Tsais t32 polished pipe
150CC ST-RR Tank
Front cva in the axles ( i mean the axles at the front diff which go to the wheels)
Rear kyosho universal shaft
Turnbuckle mod at the suspension arms
Kyosho polished chassis
st-1 pro thunder tiger truggy shocks
blue bird 14kg servo 0.15sec and 7kg servo at the throtle
dx-3.0 radio
full sealed bearings from avid
savage bevel gears in the diffs
kyosho aluminum servo linkage
topcad blue cnc knuckle arms with 3 degree negative camber
team integy 17mm hubs+16mm offset
pro-line 17mm wabash yellow 40 series rims & big joe tires
k factory 3pc flywheel
racers edge fiberglass brake disk
hpi heavy duty cups
1600mah hump style pack! and some more...
my force!
specs:
Lrp z.28r spec3
150CC ST-RR Tank
dx-3.0 radio
hpi heavy duty cups
#88
hi may i know whats the company name that sell this enslave ?
ORIGINAL: guy4x4
