ideal temperature for mammoth?
My Feedback: (158)
RE: ideal temperature for mammoth?
ORIGINAL: hansdava
are you sure because i remember that i see like 280 or something in somewhere else. thanks anyways
But it's a big wonderful world, everybodies different
Good luck
p.s. check the temp after about a minute of normal driving then again and again until you get it in the range you like.
One thing to remember is that ususally, the engines get damaged a lot in the short time that things go wrong. Not much wear takes place when all is going well.
I personally like to "tune" my engines for performance but I'm picky about keeping it below a certain temperature.
If you run it hot, make sure you fuel and needle settings are up to the job. If you have a low oil fuel, I would flirt with danger too much because a lean running condition caused by.. say a kinked fuel line can quickly damage your engine by overheating it!
ram
ram
