reverse problem
reverse problem
today i finished braking in and i was on sands and when i finshed the first tank i lat it rest and then start it again and the reverse doesn't work when i put it on revers its like on nutral, i opened the gear box nothing is broken[&:] , but when i put it reverse theres a gear comes out from another and it dislocates [&:] any things i do ??
AZ
RE: reverse problem
If it acts like its in neutral, maybe it is. Check and make sure the shift lever is moving all the way out. Make sure the idle isn't unusually high also. When you move the lever out and roll your truck forward the spur gear will catch and start to spin. Does it just roll without the gears turning? Do all of this while the truck is not running.
