LST spring rate??? Anybody know??
YT, BOTSWANA
I see the manual lists the optional springs as..
White-4.0lb rate
Black-6.0lb rate
Yellow-7.4lb rate
But whats the stock spring rate??? Has anybody seen that listed anywhere?
Matt
White-4.0lb rate
Black-6.0lb rate
Yellow-7.4lb rate
Matt
IL
RE: LST spring rate??? Anybody know??
Thermal, do you think it would be better or worse to stretch out the stock spring so that the pre-load spacers are not needed or just get stiffer springs.
YT, BOTSWANA
I wouldnt stretch them out. I dont think youd be able to get 4 identical springs that way. Just buy the option springs, they will look cool too. I like the stock suspension setup, i just want the other springs.
Matt
Matt
ORIGINAL: motorpsycho502
