RC Monster Trucks Discuss rc monster trucks in this forum
truck help
Old 08-07-2004, 09:09 PM
Deerhunter8956
Default truck help
when i put on the brake and gas it right after it dies. what would cause it to die
Old 08-07-2004, 10:13 PM
lax195
lax195's Avatar
Default RE: truck help
the idle needle.
Old 08-07-2004, 10:39 PM
TJ31
Your idle speed screw is not adjusted properly I bet... Set it just high enough so that the wheels don't turn while idling. That SHOULD solve your problem.
Old 08-07-2004, 11:46 PM
MUDSHED
MUDSHED's Avatar
It also could mean a clutch spring is busted. If all else fails, check your clutch.
