Engine Problems at 1 1/2 Gallon
OH
My friend doesn't have a account and hes at my house so im posting this for him.
His S-25 out of his Savage is having problems and its only been threw 1 1/2 gallon. It is very hard to start sometimes it takes like 15-20 minutes just to get it going, but when its started it runs like new. It's not tuning issues either i even tried to get it running for him myself and i have owned nitros for over a year. Well i guess it mgiht not be an engine problem but i don't own a savage so i don't know what else it could be. But hes been using that crap Red Alert 20% recently because he ran out of O'donnel.
RE: Engine Problems at 1 1/2 Gallon
I'm about 90-95% certain it's a bad glowplug or low battery in the glowplug ignitor.
Get a new plug, charge the ignitor and also the roto start batteries and give it a fresh start tomorrow. Also, to get it started you need to get fuel up and going into the engine. To do this hold your finger over the exhaust stinger and hold the roto-start button down for a few seconds till you see fuel move through the tubing and reach the carb. Hit it a tad bit more especially if it's a cold engine. Take your finger off the exhaust, put the glow starter on the engine and turn it over again with the roto-start. You may need to "blip" the throttle a little bit to get it to start, depending on needle settings.
It should fire right up as there are only three things needed for an engine to run:
1) fuel - make sure it's reaching the carb not stuck someplace in the lines.
2) compression - make sure the head screws are tight
3) ignition - replace glowplug if needed
