sirio .27 carb
RE: sirio .27 carb
you dont need it, just tune the thing. set the idle stop screw to 1 or 1.5 mm. then start the engine and heat it up. then adjust the hsn first, get it to where the engine has a crisp clean sream at top speed. then richen it about an 8th of a turn. next adjust the lsn while the car is at idle,if the rpm sounds high, richen it up (use 1/8 turn increments for that engine, the carb is sensitive)if the rpm is low lean it a bit. i always set my engines a little lean on high end,and a little rich on low eng, cuz if my engine gets a little warmer than i want while racing or bashing, i can just let it idle and it will cool itself off on its own. besides, there is air flowing over the engine at high speed, to cool it down.----chris
TX
RE: sirio .27 carb
Still having trouble with engine. my next try i will get a some more glow plugs, which leads to my next question, which glowplug plate is installed when you open the box? is it the standard or the turbo thats on? still only able to get it to fire up after 20 mins of work on it. any one have any sugestions?
RE: sirio .27 carb
the standard (non turbo was installed on mine) but the engine runs much better with the turbo button installed. i use rossi and sirio plugs, i'll post later and let you know which it is.and like i said in the first post that carb is very sensitive. you need only make small adjustments. good luck----------chris
