View Poll Results: A poll
Werks Picco P3 .26 PN# WRXP3M26PS
0
0%
Team Orion WASP .26 PN# 80400
0
0%
Voters: 4. You may not vote on this poll
.26 Engine: OFNA, Werks, WASP? Is there a difference?
CA
Is was thinking of getting a new engine for my LST. I would have posted this question in the LST forum, but I know that other MT racers do have experience running these engines in their other trucks. Is there any difference between the three? Some say they perform the same and some say they do not. I have selected these engines mainly because they are all Roto Start compatible and their prices are reasonable. Which engine should I get for my LST?
Here is the info gathered form their sites.
1. OFNA Picco Outlaw .26
CLAIMED HP 2.7
RPM 37,000
CARB TYPE SLIDE
CRANK SG/Threaded
CONSTRUCTION ABC
ENGINE CASE SIZE .21
ENGINE BORE SIZE .26
TYPE REAR EXHAUST
PORTS 7 ports
DISPLACEMENT .26 c.i., 4.27cc
CRANKSHAFT Heavy Duty Crankshaft 14mm
CARBURETOR Composite, 8mm insert, changeable
PLUG TYPE Standard
2. Werks Picco P3 .26
This engine gives new meaning to the word overkill. There is no substitute for displacement. At almost 40% more volume than a conventional .21, massive torque and horsepower are finally available for your Truck or Buggy! Direct replacement for any pullstart .21 engine.
2.9HP, 33,000RPM.
3. Team Orion WASP .26
HP: 2.7
RPM: 37’000
Carburetor: Slide 8mm
Crankshaft: SG type
Piston/Sleeve: ABC
Crankcase size: 21
Engine bore size: 26
Exhaust: Rear
Displacement: 0,26 ci / 4,27 cc
Crankshaft size: 14 mm
Plug: Standard
CLAIMED HP 2.7
RPM 37,000
CARB TYPE SLIDE
CRANK SG/Threaded
CONSTRUCTION ABC
TYPE REAR EXHAUST
PORTS 7 ports
PLUG TYPE Standard
2.9HP, 33,000RPM.
HP: 2.7
RPM: 37’000
Crankshaft: SG type
Piston/Sleeve: ABC
Crankcase size: 21
Exhaust: Rear
Plug: Standard
