NEED YOUR HELP SAVAGE 25 LOVERS!!!
Okay, heres the situation...
I just purchased a brand new HPI Savage 25 from a local hobby store. And now I'm having problem running it. The truck starts fine, but then as I tried to break it in, i noticed that the truck moves by itself. Moving by itself so fast that it seems like I'm throttling it 1/4 of the way. Its scary! because the truck doesnt want to stay still.
Any help would greatly appreciated. ThX in advance!
RE: NEED YOUR HELP SAVAGE 25 LOVERS!!!
i guess ur idle is to high, i thik u thought of the trim on ur radio right? otherwise u could get a new glowplug and try getting the idle screw right. i dont have a savage, but my tnx had the same kinda problems.
NV
here are a few things to check, when it is running, and you apply brake, if it stops the engine from running fast that means that you just need to adjust the throttle trim on the radio. If it doesnt, I recommend loosening the idle screw until the truck stops moving when it is topped. After you adjust your idle screw, you will need to check that your radio throttle trim is set right too. Hope this helps.
My Feedback: (-1)
check the idle screw(last thing you shoukd do)
throotle trim( do this first)
anything that has to do with the controller
servo horns are on correctly
