servo interference
My Feedback: (10)
RE: servo interference
ok first off, what are you on AM or FM? where was this occuring. it is not your servo. it is you radio. probaly someone has the same frequence or aroung your frequence to cause this.
NV
Well, whatever the servo does, does it do it all the time? and if it does it in one place, switch servos and see if it still does it. The servo itself could not glitch, it would have to be your radio system. It is possible that the servo is causing radio interference though. Cant help much more than that, unless you describe more about what it does.
