What happens when you have an air leak?
AL
I was wondering what accualy happens when you have an air leak or a leak in the tank.
Heres why:
I got all my stuff put on it, got a new clutch spring to fix the rolling problem, so i go out and run it and I retuned it because I set it back to factory. When I start it up and let it idle, it idles fine, but as soon as I hit the throttle it revs up SUPER HIGH like I've held it at WOT for 10 or something like that, and as soon as I let off it idles back down to normal idle speed.
Help please?
Heres why:
Help please?
RE: What happens when you have an air leak?
man thats like my problem i had this thease days when i added the motor saver man it got lean even if i richen it up 10 turns still hot []
Bader
KUWAIT
Bader
KUWAIT
AL
ok, me and the good people on the traxxas forums might have solved the problem, when i replaced the spring/clutch i bought the one from traxxas that says (for higher stalls) could that be the reason why it revs up so much?
