Anyone know if ofna Dominator tires fit on stock madforce rims????
NV
hey, does anyone know if ofna dominator tires fit on stock mad force rims? I figure, if they do, i could save some money, but if not, I need to buy new hexs and rims.
Any help is much appreciated.
NV
RE: Anyone know if ofna Dominator tires fit on stock madforce rims????
doesn't anyone know?
will these http://www2.towerhobbies.com/cgi-bin...?&I=LXHMH2&P=Z
fit on my stock rims?
No they will not. Mad Force hexes are 19mm and Dominators are 17mm. BUT! www.neweramodels.com makes a hex conversion kit that allows you to use 17mm hex rims.
NV
well, I know the dominator rims don't fit without 17mm hexs, but I was wondering if the dominator tires will fit on the stock rims. is your answer saying they will not? or the rims for the ofna don't fit? I already knew all about the newera 17kmm hexs and all, but I was trying to find if the tires fit on my stock rims, so I can save a buck or so if they do.
MI
From the dimensions listed at Tower Hobbies, your rims are too small of a diameter to fit pretty much any other monster truck tire. You should really measure them yourself, though, since Tower's dimensions could be way off.
I believe you can use t-maxx tires on dominator rims, too. So the tire choices there are huge.
O woops...I thought you said wheels. No dominator tires will not fit but all ClodBuster tires will.
NV
thanks all, if the t-maxx tires fit the dominator rims, my madforce rims are just a hair too small, not very much, but too small. So, clodbuster tires will fit? I guess I could look into that too!
