Picco Outlaw carb restrictor
CA
I have a Picco .26 Outlaw engine in my Associated MGT. Works great. All the power I would ever need, however, I just discovered the carb has a very nice venture restrictor. It is made on aluminum and has two o rings for sealing. A simple twist and a pull and it is out. Wow, when the aluminum restrictor is out, the carb venturi is huge.
My question is; Is there any good reason to take the restrictor out and retune. Will there be any improvment in the runing of the engine?
In my rc10 GT, I pulled the restrictor and gained some performance. My RB S7II in my Ofna Hyper 7 has the restrictor removed and runs like a raped ape.
So...... before I pull it and wreck something, would like to hear from someone who knows the adviseability or who has actually tried it.
Even though I said the Picco has enough power, unfortuniantly, I am the kind of person who thinks excess is just barely enough... LOL...
Thanks in advance,
Dennis
Thanks in advance,
Dennis
My Feedback: (10)
RE: Picco Outlaw carb restrictor
actually if you every look at RCCA horespower tips theres one were is says remove air restrictors to free up horsepower
ORIGINAL: BigGrump
Thanks in advance,
Dennis
Thanks in advance,
Dennis
WA
Actually that is not a carb restrictor. That particular part reinforces the top of the carb. If you look in side the carb you will see a lip that this piece sits on, and that the hole is the same size as the hole in this particular part. If any thing, taking this part out would only weaken the carb.
